BOM question
Brian_Nielsen
Member Posts: 5 PRO
I have one part number with many configurations. I only want it to show up once in the BOM with the quantity that I am using. How do I do that?
https://cad.onshape.com/documents/51c56c763b52d12b01b6f0cf/w/80d72ccf515beaf60ab9a87a/e/c55a96ed27364732c2f437d1
What do you think?
Its new to me.
It's pretty annoying for us as we often run into this but I'm all ears if anyone has a solution!
I did a better job with the tabulation previously, but I was working with a pro account that allowed me to use custom properties to separate L, W & D into columns.
Here is a sample that may help but again requires individual part numbers.
What your describing sounds like a holdover from a 2d drawing program or from the drafting board. Have done this sort of thing in both environments with zero associativity. There was not a lot of other options back then but manual tracking. Maybe @eric_pesty can help with column formatting via custom properties since I'm working from a free account today.
Might be time to show your guys how to do this cleaner with associativity and way faster. Need new part just add another row and up the version.
https://cad.onshape.com/documents/6f2f38f1a2b7522216ebba5b/w/30077ec248f4e1eeedf0d46e/e/1bc94d26f492c39600be06c5
What we have struggled with is having configurations representing different "states" of a single physical (think anything flexible that may have a different shape depending on where it's installed) item and having them show up as multiple items in the BOM.
I think you can now "override" qty in a drawing BOM so you can do that manually but obviously it won't update automatically if you change you assembly...
Unfortunately even with the same number they still show as individual items. Could make for a long BOM. LOL
https://cad.onshape.com/documents/6f2f38f1a2b7522216ebba5b/w/30077ec248f4e1eeedf0d46e/e/9f13a3fcd243b0805add8316
With respect to a single part having numerous configurations, you are correct that this is a holdover. But the person that pays the bills makes the rules!
