BOM column header
thomas_miglincithomas_miglinci Member Posts: 34 ✭✭✭
I would like to change the contents of the column header of a BOM in a drawing.
Especially I would like to change Part number to something shorter (which fits more in width to a simple number up to 3 digits) - e.g. Part #
Is this possible?
Thanks for any hint,
Thomas
  • S1monS1mon Member Posts: 3,745 PRO
    You can in Enterprise, if you are the admin.
  • shawn_crockershawn_crocker Member, OS Professional Posts: 914 PRO
    You can in professional as well.  Also need to be an admin.
  • glen_dewsburyglen_dewsbury Member Posts: 1,214 PRO
    You can in Pro as well. Not available in free.
  • Tanja_HofmannTanja_Hofmann Member, Channel partner Posts: 13 EDU
    You have to go to the company settings and there to the custom properties. Here you can change the displayed names of all properties.
  • jr_vrvrknjr_vrvrkn Member Posts: 125 PRO
    HI Glen, Are you sure about that? Didn't find the option.
    Yes. I did made the changes when I had a pro account and asked the same from a couple of companies I do contract work for.
    My personal account is the free version now and this is not offered as an option.
    You're right.
    Apparently my plan is called "standard".
    @stvnvl_8501 Had to look up standard. Never worked with it. But it's there under company admin tools.
