Sweep between solids is incorrect and having problems in assemblies
Jose_Montalvo
Member Posts: 12 EDU
Hello,
So I think there is an issue with an incorrect sweep that I made. When I bring it up in assemblies the different parts break off.
https://cad.onshape.com/documents/267b8aece9a2251ecaa9d496/w/e33f5a5020c0ccaccef3bc86/e/cc282a854967dece3b020d7e?renderMode=0&uiState=646e56125124585cc7b28800
Scalefist
Member Posts: 4 PRO
On Sketch 3, I added a tangent constraint to the sweep path where it connects to Sketch 2 and it appears to resolve more cleanly, is this what you were looking for?
https://cad.onshape.com/documents/63e41ae4c8ea4299ef776039/w/ff227cba36e8ad49fc8e66da/e/411e5963bdeace018cc076ad?renderMode=0&uiState=646f72b93ff64d3a62ab670b
I had to fix the whole knife part to prevent it from moving apart
https://cad.onshape.com/documents/267b8aece9a2251ecaa9d496/w/e33f5a5020c0ccaccef3bc86/e/1bc1a741954c7491cd1234fd?renderMode=0&uiState=646e56d75124585cc7b28ce3
I'm fairly new to OnShape myself, but going through the Learning Center self-paced lessons.
When sweeping, the orientation of the profile to the path is preserved along it's length to keep the cross-section consistent.
If a more oval cross-section is desired, I suppose you could start at whatever angle you like and simply sweep into the geometry instead of terminating at the surface.
