Dimension and extended direction
ben_jiang418
Member Posts: 5 ✭
This might be stupid: Let's say I have a 3mm horizontal line. If I use dimension tool and set the length to 6mm, the line is always extended towards the right, eg, the right end always get moved. Is there a way to move the left end instead?
glen_dewsbury
Member Posts: 1,305 PRO
You can fix a point along a line as in this example and it will resize accordingly.
Show constraints in the sketch should make this clear.
Try adding a dimension to each of the 3 lines and note direction of change.
Usually these points are fixed by some other entity.
Just 1 of many ways.
https://cad.onshape.com/documents/51c56c763b52d12b01b6f0cf/w/80d72ccf515beaf60ab9a87a/e/00615a870150f26f26892295
If any element of the sketch is blue, it's not fully constrained, which makes it difficult and dangerous to predict what will happen.
I would recommend going through the online training.
https://learn.onshape.com/courses/fundamentals-sketching
