using existing parts for a new part
Hi,
I've got a bunch of small parts I getting printed at the library, so I have to work with their requirements.
they have a setup fee for each part, which I'd like to avoid.
Therefore, I would like to take a bunch of parts from more than one part studio, and move them into another part studio ( can be the same document, or another document), and assemble them on a flat plane, then create plastic ribbons to join them together, like a plastic model, so they will show up as one part. then after printing I can just trim away the ribbons, but it all gets printed in one setup.
Note: this is not an assembly, with connectors. I plan to merge all into one part.
my question is: How do I copy these parts into the new workspace, so I can merge them together in a different configuration from the way they were designed? And when I do that, will they be dimensionally connected to the original, for modifications?
Thanks for your help.
eric_pesty Member Posts: 2,338 PRO
https://cad.onshape.com/help/Content/derived.htm?Highlight=derive
And then use transform tool as needed to locate them relative to each other.2 -
I didn't look closely and didn't see there was a taper so that makes sense!
The split in the sketch is due to the "imprinting", see details here: https://cad.onshape.com/help/Content/sketch_basics.htm?Highlight=imprinting0
here is the link to my combined workspace: https://cad.onshape.com/documents/d7f2fab8f7c37bf43928ad17/w/e787440fe1af082586af7422/e/e6996adab9c5688046400aca
one of the "clamp halfs" won't merge.
first I used "transform" to create a copy of it, it did not merge.
so I thought it's because it was linked back to the original part, and I could not merge it to itself.
I created a "version" of it in the original document, and imported, via derive, a version 1, and a version 2. still won't merge.
then I created a full copy of the whole workspace, and tried to import the second half from there. this is the existing layout.
still won't merge. you can see that there are two parts in the parts list, and I want only one.
Thanks in advance
In your extrude at the end just make sure to include the area that overlaps the clamp part and it works.
Thanks again.
