is it possible to suppres the same part from different configurations in the same assembly.
stvn_vlstvn_vl Member Posts: 125 PRO
Hello,
I have a challenge where several parts get unsuppressed in an assembly by one configuration.
choosing another "option" later on suppresses some of these parts yet again. Is this possible? what is a good strategy?
the example is a frame with legs: if I choose the option "with legs" and later choose to add another frame, 2 of the legs become redundant and have to be removed again. (well its a bit more complex, but that'll illustrate best)
  • eric_pestyeric_pesty Member Posts: 2,127 PRO
    You can't do it easily but one workaround is to use a folder as you can configure the suppression of a folder with one configuration input and what is in the folder with a different one, so you can get two "options" that way.
  • stvn_vlstvn_vl Member Posts: 125 PRO
    Thanks, interesting idea. I will try that and get back to you on the results.
  • John_vd_WerffJohn_vd_Werff Member Posts: 65 PRO
    @eric_pesty, neat trick!
    I was looking for a way to have conditional configurations, this workaround could accomplish that in some situations.
    thanks @eric_pesty that worked just fine!
    great thinking.
