offsetSurface FeatureScript Documentation Incomplete
Jonathan_Hutchinson
Member Posts: 142 PRO
Here is an example of how you can use it:
opExtractSurface(context, id + "extractFace", { "faces" : yourQueryHere, "offset" : 0 * inch }); qThisSide = qCreatedBy(id + "extractFace", EntityType.FACE);And here is some more info about it:opExtractSurface (context is Context, id is Id, definition is map)
For Onshape internal use.PARAMETER INFO
definition is map- faces is Query
List of faces to be converted. If tangentPropagation is true, these are the seed faces.
- tangentPropagation is boolean optional
Whether additional faces should be added to the selection by tangent propagation
- offset is ValueWithUnits optional
Offset extracted surface faces by this distance along normal
- useFacesAroundToTrimOffset is boolean optional
Use surrounding faces extensions to trim offset. Default true.
- redundancyType is ExtractSurfaceRedundancyType optional
