Unpack Folders
Rhett_RobinsonRhett_Robinson Member Posts: 169 PRO
Within a document you can unpack tabs from a folder and retain the workspaces, but outside the document in the folder view this isn't an option. It is annoying when consolidating folders to move the documents contained out and then delete the empty folder as a separate step.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,933 image
    In a document you can undo an accidental unpack, but you can't on the documents page - that is the reason.
  • Rhett_RobinsonRhett_Robinson Member Posts: 169 PRO
    edited June 2023
    @NeilCooke Wouldn't you just be able to recreate the folder and drop the documents back in? I don't think I understand why this would be an issue.
    You would need a photographic memory to know what was in there, possibly.
