Unpack Folders
Rhett_Robinson
Member Posts: 169 PRO
Within a document you can unpack tabs from a folder and retain the workspaces, but outside the document in the folder view this isn't an option. It is annoying when consolidating folders to move the documents contained out and then delete the empty folder as a separate step.
