Error while trying to animate my project.
Error: Unable to compute any steps for this animation. Unable to apply transform. Instance(s) may be constrained.
I'm able to animate the project when I animate using one of the revolute mates. However, it gives me this error if I try animating it with other mates.
Project: https://cad.onshape.com/documents/f854a2107b28fd0555185949/w/4d4f9cba2786a15ea34e8ead/e/e3bd1c8b658fdbbb2f0d1b65?renderMode=0&uiState=6487aebf9308240326fbd833
I don't know if I can give edit access through link-sharing.
When I copied your document and supressed the cam (part 1) I could move the shaft. I think you're problem might be the tangent mate since your cam has a flat section moving would violate that mate. If you want to keep that mate try making the entire cam curved. Otherwise try making a screw relation.
