Dimension text location - how to move above dimension line.
geeveemohan
Member Posts: 6 ✭
Hi Team,
Is there any way to move the dimension above the dimension line, as shown in the attachment
Is there any way to move the dimension above the dimension line?
Another question is how to connect the inspect symbol centerline to the dimension line.
Oddly, I couldn't find a way to switch location once the drawing had been started with in the drawing properties.
The templates I used are the OS defaults.
Maybe it's too early in the day for me.
Use ISO drawing templates for your dimension to be displayed above the dimension line.
Where do I find the setting to use or change those ISO defaults? In NZ, students are required to have the dimensions above the line
