How to use shell feature on one face
silas_bastiansilas_bastian Member Posts: 2 EDU
First of all, I am new to Onshape. This is my second project.
I am designing a guitar body, and I want to hollow out a cavity for electronics, and the shell feature seems like the best option. The problem is shell hollows out the whole model like this.
I want it to be hollow only below the selected face. Maybe extrude is a better option? The problem with extrude was I couldn't figure out how to shrink non-proportionally so the thickness is the same around the edge of the cavity.
  • Axel_KollmenterAxel_Kollmenter Member, pcbaevp Posts: 436 PRO
    Welcome to Onshape ;)
    You could extrude and start with an offset of your wall thickness.
    Best regards,
    Axel Kollmenter
  • David_YL_NguyenDavid_YL_Nguyen Member, Onshape Employees Posts: 181 image
    Another option could be to split you body and only use the shell feature on the right half.
    Best regards,
    Axel Kollmenter
