Francis turbine | Spiral case | Weird loft along path
petr_bláha69
Member Posts: 6 EDU
in General
I am working on a Francis turbine school project that will be used for a fluid flow demonstration and for a real 3D printed model. But at the moment I'm stuck on modeling the spiral case.
https://cad.onshape.com/documents/03aa0b510e7bf1da4c64e519/w/c6e545882276973a5ed4feb1/e/6fa7e6f6599d3ae023813181?configuration=snaildiam=0.2+meter;snailsize=0.08+meter&renderMode=0&uiState=649160d46cbcaf67f6d2430e
I have the first sketch in the top plane as a snail trajectory for "Loft" along the path. Next to this path I have other planes with circles corresponding to the cross section of the spiral tube. When I loft from one cross section to the other, I get an object, but this shape is weakened in the middle and the resulting shape is distorted.
Is it possible to make the resulting shape in Onshape so that the Loft transitions evenly from larger to smaller?
Thanks for any idea :-)
Is it possible that you are using an education licence of Onshape? In that case you need to make the document public.
I tried to open your link but was not able to access.
Thanks,
David
Thank you.
https://cad.onshape.com/documents/58f0590e783b3bab7b7cbc6c/w/7a147a74c899c518d2178d51/e/9b7604138d7fef1c0f95e4cd
Take a look at the end conditions of the loft to see if you want to incorporate what is showing
Petr
Petr
I’ve added 2 Part Studios
With regards to the below definitions for the part studios — all three part studios are to be viewed from overhead looking downward, i.e. from TOP VIEW
Circular Inside —
The inside edge of the horn is circular
Circular Centerline —
The center of the horn is circular
Roughly Circular Inside —
The inside edge of the horn is roughly circular
Check my document above
There is now an inside spiral
I’ve added another part studio
This one follows a spiral that is at the center of the horn
