How to mirror an object without copying it?
blackslate
Member Posts: 18 ✭
I want to move an object into its position in a mirror defined by an arbitrary plane. I do not want to create a copy.
Below is how I can achieve this using opPattern, and then deleting the original. Is there a more elegant way?
On this page, from 2017, Jake_Rosenfeld suggested to try something like this...
mirror(context, id + "mirror1", {
"patternType" : MirrorType.PART,
"entities" : someQueryForEntities,
"mirrorPlane" : someQueryForTheMirrorPlane
});... but this is no shorter* and also creates a copy, as you can see here.
(*Perhaps it is more efficient?)
You can see my working (but inelegant) version in action here.
FeatureScript 2066;
import(path : "onshape/std/common.fs", version : "2066.0");annotation { "Feature Type Name" : "Mirror Test" }
export const mirrorTest = defineFeature(function(context is Context, id is Id, definition is map)
precondition
const goldenRatio = (1 + sqrt(5)) / 2;
const goldenCorner = vector(1, goldenRatio) * inch;
// Draw some construction lines
const sketch1 = newSketch(context, id + "sketch1", {
"sketchPlane" : qCreatedBy(makeId("Top"), EntityType.FACE)
skRectangle(sketch1, "rectangle1", {
"firstCorner" : vector(0, 0) * inch,
"secondCorner" : goldenCorner,
"construction": true
skLineSegment(sketch1, "line1", {
"start" : vector(0, 0) * inch,
"end" : goldenCorner,
// Create a rectangle to extrude
skRectangle(sketch1, "rectangle2", {
"firstCorner" : vector(1, 0) * inch,
"secondCorner" : vector(1.1, goldenRatio) * inch
skSolve(sketch1);
// Create a mirror transform
const x = normalize(vector(1, goldenRatio, 0));
const normal = cross(x, Z_DIRECTION);
const mirrorPlane = plane(WORLD_ORIGIN, normal, x);
const mirrorTransform = mirrorAcross(mirrorPlane);
debug(context, mirrorPlane, DebugColor.RED);
// Extrude a shape
opExtrude(context, id + "extrude1", {
"entities" : qSketchRegion(id + "sketch1"),
"direction" : Z_DIRECTION,
"endBound" : BoundingType.BLIND,
"endDepth" : 1 * inch
// Mirror it
opPattern(context, id + "pattern1", {
"entities" : qCreatedBy(id + "extrude1", EntityType.BODY),
"transforms" : [mirrorTransform],
"instanceNames" : ["mirror"]
// Delete the original
opDeleteBodies(context, id + "deleteBodies1", {
MichaelPascoe
Member Posts: 2,797 PRO
Try something like this:
https://cad.onshape.com/documents/afedfd6fe11ea21e5eec3375/w/72b...
annotation { "Feature Type Name" : "Mirror transform" } export const mirrorTransform = defineFeature(function(context is Context, id is Id, definition is map) precondition { annotation { "Name" : "Entities", "Filter" : EntityType.BODY } definition.entities is Query; annotation { "Name" : "Mirror plane", "Filter" : EntityType.FACE, "MaxNumberOfPicks" : 1 } definition.plane is Query; } { const mirrorPlane = evFaceTangentPlane(context, { "face" : definition.plane, "parameter" : vector(0.5, 0.5) }); opTransform(context, id + "transform1", { "bodies" : definition.entities, "transform" : mirrorAcross(mirrorPlane) }); });
RENDERCAD
________________________________________________________________________0
annotation { "Feature Type Name" : "Mirror transform" } export const mirrorTransform = defineFeature(function(context is Context, id is Id, definition is map) precondition { annotation { "Name" : "Entities", "Filter" : EntityType.BODY } definition.entities is Query; annotation { "Name" : "Mirror plane", "Filter" : EntityType.FACE, "MaxNumberOfPicks" : 1 } definition.plane is Query; } { const mirrorPlane = evFaceTangentPlane(context, { "face" : definition.plane, "parameter" : vector(0.5, 0.5) }); opTransform(context, id + "transform1", { "bodies" : definition.entities, "transform" : mirrorAcross(mirrorPlane) }); });RENDERCAD
