Does Return Statement Exit from features as well as functions?
Jonathan_HutchinsonJonathan_Hutchinson Member Posts: 113 PRO
Take the below example in a feature body:
        if (definition.inputMethod == InputType.DIAMETER_VALUE)
            setVariable(context, definition.variableName, rounded);
            return;
Should this not execute any further code within the feature? I am currently seeing that it doesn't, at least not without an else block. Which I guess makes sense, but I thought the return statement would override anything else and run no further lines.
Another interesting thing I noticed is that, it seems, things done above a throw aren't carried out if a throw is encountered. So in the below example, on the condition of something, change the value of a variable, and also provide an informative throw. But that seemed to negate the action of setting the variable. Is that expected behaviour? Or is throw not the right thing to call in this sort of case?
        if (!isundefinedoremptystring(something))
            throw "message for the throw";
  • caden_armstrong2caden_armstrong2 Member, User Group Leader Posts: 121 ✭✭✭
    Yes, a return statement in a feature main body will stop the feature from progressing. If you find that is not the case, perhaps your if statement is not being entered. Add a println statement in to double check.
    Throw is meant for exceptions. If you want all the code to run, and then stop and show a message, you can use reportFeatureWarning or reportFeatureMessage.
  • EvanReeseEvanReese Member, Mentor Posts: 2,410 ✭✭✭✭✭
    I have a ton more to learn about featurescript, but I've only ever used "return" in editing logic or a manipulator change function, in which case, It would be "return definition;", not just "return;"
    @Evan_Reese I only use it when I am debugging. Throw a return statement into a feature half way to keep the rest from running.
    Return; isn't obvious in featurescript because you don't need to declare function return types. Void isn't a thing.
    great to know! thanks
