How to select or define mdf panels for a cut list
breandan_murray
Member Posts: 8 ✭
When I deign furniture I use beam, but the timber optiions are limtied to from a size of 1x 8 to 8 x 8.
I am seeing no options for for panels, e.g MDF panels 2400mm * 1200mm
Am I using the wrong tool, any help would be much appreciated
MichaelPascoe
Member Posts: 2,687 PRO
@breandan_murray, If you share a link to your document, I'll take a look at your specific issue. There are simpler ways to get a panel cut list. Especially if you are new to Onshape.
CADSharp - We make custom features and integrated Onshape apps! Learn How to FeatureScript Here 🔴0
Hey @breandan_murray,
The Beam feature has been fully integrated directly into Onshape's native features now as Frame. It has the option to define custom profiles. This might fit your needs. When you select the profile sketch, there is the option for "Current document" or from "Other documents". This is where you can select your own custom profile.
To do this, it will be best practice to set up a configured sketch in its own part studio; this way you can easily re-use it with whatever size you need. When the profile is used in another studio, you will be able to have any value you like. See these steps:
https://cad.onshape.com/documents/4a19637188242256528d7de3/w/f845c2477cde621aa1447632...
Thansk again
