How do I query for an image in a part studio
billy2billy2 Member, OS Professional, Mentor, Developers, User Group Leader Posts: 2,115 PRO
edited June 2023 in FeatureScript
I'm trying to fix superderive. My thinking is because you're replicating MCs, why can't I replicate images?
here's the image:
how do I get it from the var selectedparts"
  • MichaelPascoeMichaelPascoe Member Posts: 2,728 PRO
    I believe the image data is attached to the construction edges around the image. They can be moved away from the image, but when you go to delete them, the image gets deleted too. Perhaps there is a way to get the attributes from the edges. You will probably need to use some edit logic for this, fun stuff.
    edited June 2023
    While querying the incoming derived part, I see no sketch entities.
    They retrieve MCs using qMateConnectorsOfParts to retrieve all MC in the incoming parts.
    Thinking life is simple, I tried
    qSketchFilter and get nothing that looks like a sketch.
    I'll review your image code and see if I'm missing something.
    Thanks
