Improvements to Onshape - June 29th, 2023
Welcome to our second release of June and, once again, it includes a wide variety of features: surfacing, drawings, productivity tools, usability improvements, and more. Let's take a look.
GENERAL IMPROVEMENTS
All current Onshape library profiles have also been made publicly available. If you wish to entirely manage your own library and include a subset of the standard profiles as well, you may copy them from the links below
ISO:
Onshape Inspection items are now visible directly in the Drawings environment from a panel on the right hand side.
DIHEDRAL ANALYSIS
A new evaluation tool for measuring the dihedral angle between two faces is now available: Dihedral analysis. Click the Show analysis tools icon at the bottom right corner of the screen to access this tool. Note that Interference detection and Curve/edge analysis tools are also accessed from here.CREATE ISOCLINES
A new feature to create Isoclines (curves on a face) is now available. Select one or more faces, a direction of reference, and an angle. Isoclines are useful for generating silhouette curves and tangency lines for adding manual draft.CUSTOM FRAME PROFILE LIBRARIES
Users may now create and manage their own Frame profile libraries. Professional and Enterprise licenses allow companies to have a shared frame library managed by an administrator. In addition, each individual user can set up their own frame profile library folder for their own use.All current Onshape library profiles have also been made publicly available. If you wish to entirely manage your own library and include a subset of the standard profiles as well, you may copy them from the links below
ISO:
- Rectangular bar:
https://cad.onshape.com/documents/fb43e175708c35044f398086/w/61958daa830dadcdda29d131/e/25188ecfb1a2be5eaed1b60d - Rectangular tube:
https://cad.onshape.com/documents/314151a71d716828eb4c8fee/w/544042879d0dc2be18e44620/e/cc759d44ed162d05eb732ea5 - Round bar:
https://cad.onshape.com/documents/9c903644ea11db6adcea465a/w/550b015c47e6cd7be9393577/e/79223fe5ce8530869d7e64ce - Round tube:
https://cad.onshape.com/documents/2b0ae53bcb8f9f64dbe0b46b/w/3456f5333796c2fa52991f40/e/469c227372dc368ce80d8ff
ANSI:
- Rectangular bar:
https://cad.onshape.com/documents/aa06d5468b3bc366947ba7f0/w/7053c6e94b40041d3301a7de/e/6b92c44fcf228039bd90042b - Rectangular tube:
https://cad.onshape.com/documents/afd89bc349544bd249b47b01/w/a77d488c65e2ef41fc9ad304/e/94de058aece357024ba47a5a - Round bar:
https://cad.onshape.com/documents/c78d9408bd2a4f9a4d96ee47/w/c7d5cc061d0532e31ad786c7/e/0eb6dbcf8df0653e1add0b13 - Round tube:
https://cad.onshape.com/documents/960efb7145a7c51864404e8c/w/8b7a17c81a44075d30b25319/e/0090ceaa58bb9b06d61f525
8020:
- 15 series:
https://cad.onshape.com/documents/a12cf35720ce8c559f4e67aa/w/ddfbac1f092ba3003d894e97/e/251436e84a71ad1e2370ad16 - 10 series:
https://cad.onshape.com/documents/9ea71701c83a78369e7ad711/w/67c099a58ab26d020a8c9c9b/e/0634a2c202a8b7775b84a37c - 20 series:
https://cad.onshape.com/documents/526d3d20f913af1fc9d70e31/w/b654d379e439f25d7e19e87e/e/95001d1786459e6b776d4bfe - 25 series:
https://cad.onshape.com/documents/acd12776acac5a988fb16007/w/80390c7b283d2b7ed7095703/e/da6285b6c52a834a36d5589e - 30 series:
https://cad.onshape.com/documents/e0716981ab3eb957f9598280/w/0f65c55865ab58519c9e3dbb/e/93bca45c1da52ac8506d5210 - 40 series:
https://cad.onshape.com/documents/497d65cd254360a25474589b/w/444a194914262a02bf240cdf/e/78821b504d5500b0323c2b10 - 45 series:
https://cad.onshape.com/documents/ce730d2f03deebc43dd260cf/w/d91aa0f98d07678fb659cd29/e/a1eab51bd85471085cc397e8
AS:
- Cold formed hollow sections:
https://cad.onshape.com/documents/1828c2eb863ee177b5a1d699/w/34fdabc05c992a4a90051411/e/ac4a99673478726ffe8a2c1a - Hot rolled and structural steel:
https://cad.onshape.com/documents/7f325d6f220d7f8fc87a6635/w/56e13492d6c1af38267c917b/e/57b5ea6e9fdad7bf24af08ae
ASIC: - https://cad.onshape.com/documents/222d833563d2b359395e721d/w/6b9a9afcc77cf7436fd84734/e/2638efb9136a999d65aed13d
DRAWING IMPROVEMENTS
INSPECTION TABLE PANEL
Onshape Inspection items are now visible directly in the Drawings environment from a panel on the right hand side.AUXILIARY VIEW: ANGULAR DIMENSION TO VIEW INDICATOR
You can now dimension directly to the arrow-style view indicator for an Auxiliary view. This is a convenient way to call out the angle of the Auxiliary view.PROJECT SECTION VIEW WITH CUT
When projecting a section view, you now have the option to include the cut in the resultant view. By default, the cut is not shown, but you can hold the SHIFT key before placing the view to enable it. It also can be turned on or off at any time from the view properties.ENTERPRISE IMPROVEMENTS
DOCUMENT DASHBOARD: PUBLICATIONS REFERRING TO DOCUMENT
The Document dashboard now includes a Publications Referring to Document field. This shows how many (and which) publications have an element from this document being referenced. You can think of this like a Where used but specifically for finding Publications.
IMPROVED PERFORMANCE OF TEAM ACTIVITY DASHBOARDS
Changes have been made to Enterprise reports to drastically improve the load time when drilling down into specific Team Activity dashboards. In certain instances, it is reported to load 4 to 5 times faster than before.Please take a moment to try out these new features and improvements and leave your comments below. For a detailed list of all the changes in this update, please see the changelog.
Remember: The updates listed here are now live for all users when creating new Documents. Over the next few days, these features will also be available in Documents created before this update.8
https://thesmoothcut.com/
Also had no idea I could make an arrow style Auxilery view.... Welp better late then never hahaha!
Got some drawings to clean up
See also:
https://forum.onshape.com/discussion/20405/show-isocurves-seems-out-of-place
Axel Kollmenter
Agree with @S1mon that there are more analyses that can move to that button.
Dihedral analysis is comletely new to me. I guess i would have used isoclines to judge this normally, Dihedral seems more precise.
Does anybody have tips on where to study advanced surfacing? (and i mean fundamentally the quality of design and fundamental features, not just how to make it in Onshape). I've learned a lot in my job and in practice, but would love to learn how/where to take the next step.
I didn't try it yet but... For the custom profiles, is there a way to assign part numbers? For instance if the base part number is ABC123-Length, can the length be a suffix? ABC123-350
For Aux views, it would be cool to one day have the centerlines align with the view!
Nice work and a nice surprise!
This will help quite a few users out. Nice improvements Team!
Especially the Frame libraries. Will be showing this to a client next week.
Good point. This might also be a prelude to "custom standard" content libraries.
En este enlace podéis ver las Novedades de Onshape en español:
Great to see Inspection Table updates, love how Onshape does not let minimum viable release features linger for long without getting some polish.
Custom Profiles for Frames, huge for us and our extrusion kitting business.
Thank you Onshape.
