Urgent. How to make abha style torus with this pattern, clearlier explained
Hi. I am still searching to get working this style of pattern for torus and i was asked this earlier but there wasnt solution for this what i need, it is important that all lines are as one long line throught donut surface, not like 12 circles closed indipendent lines as what i got as answer earlier.
I did more days search and did get know that it is called "torus knot path" and this will be for copper wire to wrap wire around as one long lenght.
Example if torus diameter is 14.5 centimeters then there will go 7 meters long wire throught it, first to right and up clockwise then right and down in anti clockwise.
First picture how it need to be and second picture is with different style frame but shematic same almost ready where can see that there is throught one long wire, just little bit too short but anyway i hope that it will help to understand.
1
https://cad.onshape.com/documents/b46b73bb4583cd2b3209892e/w/a496509da409cef9ea74d8a3/e/1555351a6464184ecfdc689a
Independent Onshape Consultant
4 features
WOW
Pretty doggone cool !!!
Yes that is much closer already, thanks, i checked it in my case i need 12 times around and it was impossible to me to understand this deeper, and, yes, changed to 12 but still nothing, so would be good for some manual what and how.
Sorry for my begineer position.
https://cad.onshape.com/documents/49d65188db8609de89a767d2/w/d3de9c007e566ad7341690a8/e/31f8a28c0d8abed5daad087d
