Airfoil loft problem
leha44581_leha
Member Posts: 2 ✭
in General
I can't make a loft between 2 airfoils, tried using some guides and paths, but it just doesn't work.
If i won't use any, it creates a self intersecting shape.
Imported airfoils with the aerofoil script by Darren Lynch.
https://cad.onshape.com/documents/fb5b49751cbc52193856bd7a/w/f93f7747c84f3d910949a03e/e/5aec9d002344d5629b842c3d
A better approach might be to edit the Profile generator feature and change the Spline type parameter to "Upper and lower splines". This will give you two spline curves which you can use to create a surface loft for the upper, then a surface loft for the lower. Here is a quick test:
If you try something like this you'll still have to check the curvature of this resultant surface, and it will still not be great. This is because of the foundational curves you are using. A much better approach will be to remake these curves (using the Profile generator curves as a guide) in a new sketch and use a Bezier curve with far fewer control points.
I would also look at your Loft 2 feature and consider using "Connections" rather than those guide curves. You can experiment very easily with Connections... That transition in the root of the blade (i.e. Loft 2) could also have some tangency condition applied. Lots of possibilities!
Ideally, a proper “rebuild curve” feature would make this much easier to do in an automatic controlled way. Hint, hint…
Clean the input data up 1st, you'll be glad you did.
This is a common problem in the industry.
Switch the profile generator from single spline to upper and lower will let you select the face of the profiles with out the loft connections. The rest is just me playin around to see what I could come up with.
https://cad.onshape.com/documents/0de5a971db26bab87c5bfce9/w/68128340bd6c29e967a751a3/e/48b8e0a979c257228049d79c
