Is it possible to rotate centermarks in drawings?
Axel_KollmenterAxel_Kollmenter Member, pcbaevp Posts: 436 PRO
I like to rotate the centermarks to 45°. Is there a way to do this? Or is there a special option only for slotted holes?
Best regards,
Axel Kollmenter
    I've not seen anything like what you're asking for.
    It can be done with the centerline tool using 3 centerlines. Not as convenient but it works
  • Axel_KollmenterAxel_Kollmenter Member, pcbaevp Posts: 436 PRO
    Alright, I also came up with this idea. Good to have you with the same idea haha thanks
    Best regards,
    Axel Kollmenter
