Query that Resolves to nothing != qNothing()
Jonathan_HutchinsonJonathan_Hutchinson Member Posts: 113 PRO
edited July 2023 in FeatureScript
I stumbled on some strange behaviour I couldn't figure out. What I thought was quite a straightforward conditional where I do a qSubtraction, resolved weirdly. As below.
                const allGeom = qCreatedBy(id + "extrudeThin", EntityType.FACE);
                const planeGeom = qGeometry(qCreatedBy(id + "extrudeThin", EntityType.FACE), GeometryType.PLANE);
                const curvedGeom = qSubtraction(allGeom, planeGeom);
                debug(context, allGeom, DebugColor.RED);
                debug(context, planeGeom, DebugColor.RED);
                debug(context, curvedGeom, DebugColor.RED);
                if (curvedGeom != qNothing())
                    println("is something");
                else
                    println("is nothing");
Returned in the console:
debug: Query resolves to 6 faces
debug: Query resolves to nothing >>> (curvedGeom variable)
is something >>> (curvedGeom variable, resolves to nothing but isn't equal to qNothing?)
My workaround is to evaluate the query and test if it's equal to an empty array. But I thought equality to qNothing was possible?
  • Jacob_CorderJacob_Corder Member Posts: 137 PRO
    qNothing is a query structure and is only the same as another qNothing(). An empty query will not resolve to qNothing() it will return [] from evaluateQuery and false with isQueryEmpty. To solve your current code, the fastest ways is
    if(isQueryEmpty(curvedGeom)==false)
    so, use isQueryEmpty(curvedGeom)
  • Jonathan_HutchinsonJonathan_Hutchinson Member Posts: 113 PRO
    edited July 2023
    Ah, thank you! I don't know why I had it in my head that comparing to a qNothing would help me out.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,866
    Or, even more succinct:
    if(!isQueryEmpty(curvedGeom))
