How to extrude (delete) with loft and remove 'legs' under dome.
Hi all,
I am new to Onshape and had some questions. I try to design something relatively simple but somehow I can't get it done.
The idea is to create a tapered tube with a round dome at the bottom.
When I am designing I first created the dome OD 54mm and ID 50mm and the recess OD 14mm and ID 12mm, here the first problem arise.
When doing this I somehow cannot remove the excess material which is now sticking out underneath the dome.
1st question, how can I remove these 'legs'
When I continue I make an offset plane and draw the same sketch on top of it besides the the dimensions of the inner and outer diameter of the tube.
I created a sketch with OD 64mm and ID 54mm to make it tapered.
Here I run into a problem since I want the tube to be hollow (of course otherwise it wasn't called a tube XD.)
2nd question, since the 'tube' is tapered how do I extrude (delete) the inside of the tube? I have tried loft but somehow doesn't work.
Thanks in advance!
Kind regards,
Mitchell
  • MichaelPascoeMichaelPascoe Member Posts: 2,825 PRO
    Hi @mitchell_meeuwesen, there are a few different ways to do this.
    You could copy the main body using Transform before the legs were attached, then use Boolean intersect
    Please share a link to your document so we can help you better.
    The inside of the tube can be hollowed out using the Hollow feature.
    RENDERCAD
