Involute using parametric curce
Hi,
I am trying to generate an involute profile for gear tooth and facing some troubles using the parametric curve feature script.
This is the equation I am trying to implement.
I checked the examples from the feature script. Using multiplication in the cosine function works but when I try to add, it does not work. Please point out where I am going wrong.
Thanks
Thanks
