Countersunk Holes
Is there a custom featurescript to do multiple countersunk holes (like you get in fusion 360)? I know I can draw holes on the sketch and then chamfer them but when you have a lot of holes it's a bit tedious.
If not, then it is definitely a core onshape feature I would like to see.
  • David_YL_NguyenDavid_YL_Nguyen Member, Onshape Employees Posts: 163
    Hey @stephen_sherwood846,
    Just select the Hole feature with "Countersink"option and select your whole locations from a sketch or mate connectors.
    Is that what you are looking for?
    Cheers,
    David
  • stephen_sherwood846stephen_sherwood846 Member Posts: 26
    Yes, sorry - No idea why I couldn't find it before.
