Is there a way to Calculate the entire surface area across a plane?
Cobalt_Echo
Member Posts: 31 ✭✭
I would like to know the total surface area across the Front plane. I tried projecting the entire object (car) onto a sketch but some parts wont project (like those highlighted in the picture). Anyone have sugguestions?
https://cad.onshape.com/documents/48ae26d85b38e37616e5ef13/w/460c25fce0ab4a7546d49854/e/5dd60ca24375221dffae5aab?renderMode=0&uiState=64a58f93e7956a663bb4cd66
eric_pesty
Member, pcbaevp Posts: 2,473 PRO
The "project body" featurescript should be able to do that for you:
https://cad.onshape.com/documents/201b33ee5450cefbca3b34b8/v/9028ee782ed5ec471178bca1/e/858d76e3ccedcf5b31bf74ad
3
Improvements to Onshape - June 29th, 2023 — Onshape
If you have an assembly you just have to create an in-context part studio first and you can project the context directly (or maybe you have to do a "copy in place" first, I don't remember).
I am still regularly amazed at how many time-saving Featurescripts are out there, the real challenge being to know about/find them which is why I try to post any relevant ones I can think off in all these threads as this is how I "discovered" most of them!
