Can onshape convert this model into a solid?
carlos_berdealcarlos_berdeal Member Posts: 76 ✭✭
 I am trying to make this a solid. Can it be done? If so can someone point me that way? Thank you!
  • glen_dewsburyglen_dewsbury Member Posts: 1,061 PRO
    @carlos_berdeal
    The derived part has been converted to a solid during the import because of the option to join adjacent surfaces.
    Is this a scanned model? It is non uniform and certainly not symmetrical. That's why it has the surface split up all over the place.
    OS is having difficulty with the shell because some of the surfaces are trying to fold back on themselves, particularly around the dimple. I changed the shell to 0.01 and it worked but trying to increase thickness caused a serious performance issue.
    https://cad.onshape.com/documents/a3f482a5c6fb94d76a65f0e2/w/dd08b28ca3506681d2b451f3/e/5d6a3f456edeee48d8355145
    If you feel a need to rebuild for accuracy, I generated part studio 2 as an example. You would want an approximate trace of the original of course.
  • carlos_berdealcarlos_berdeal Member Posts: 76 ✭✭
    @glen_dewsbury Would this be a better model to work with as I filled in the dimple? What process do you use?
    @glen_dewsbury How do I see part studio 2 I do not see it. Thank you for your help as well.
  • S1monS1mon Member Posts: 3,344 PRO
    You can use this model as a reference, but I would never use those surfaces for anything which was going to be manufactured. A quick 3D print - maybe.
    You will need to create clean curves, and then you may be able to create good surfaces which can be used for downstream detailing.
    What tool was this originally modeled in? How was it exported?
    What are you trying to do with the shell?
    This surface topology is really bizarre. I've never seen anything quite like this.
    @carlos_berdeal
    SRY. Missed your question. Meant to say part studio 1. There may have been a studio 2 but got deleted.
  • lanalana Onshape Employees Posts: 728
    I'm guessing sub-div exported as NURBS
    Agree with S1mon - if you do any sort of modeling based off this geometry, the result are not going to be great.
