Draw Isometric view of the following Object
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 942 PRO
    As discussed here, you can create isometric views in Onshape drawings, but the dimensions will be the projected lengths, not the true lengths.  You can override them, but that is a manual process.
