Please help me understand why the dimensions on my drawing seem incorrect to me.
PahlPahl Member Posts: 42 ✭✭
edited February 2017 in Drawings
Here is a drawing I found online that I'm working with as a exercise.
I can create the model with the correct dimension but I'm having trouble getting these three dimensions to display correctly on my drawing.
When I go to create the drawing this is the best OS seem to do.
How do I correctly display them three dimension on my drawing?
Edited to add:
I see how to manually add the dimension to show what ever I want, but shouldn't OS be able to automatically display these three dimensions like it does for the rest of the dimensions on my drawing?
Here is my model.
https://cad.onshape.com/documents/941b9c69311c0ca8e4886864/w/eab2e84dcc88f6a53636bf92/e/e3d7e0d8bc934967d0973f5d
Here is my drawing.
https://cad.onshape.com/documents/941b9c69311c0ca8e4886864/w/eab2e84dcc88f6a53636bf92/e/41b369c67afd6c09d2d284cd
Thanks!
    Dimensioning in an isometric view gives you the projected lengths onto the sheet, not what the model dimensions are.  If you were to print it to scale and measure those lines with a ruler, you would be getting 16.9, 13.85, and 6.96 as the length of the lines.
    Jake Ramsley
  • PahlPahl Member Posts: 42 ✭✭
    Hi Jake
    Ok, that makes sense. How would a professional go about showing these three dimensions on a drawing for this part?
    Maybe the 17x17 as shown on the original image I'm trying to work with has the dimensions displayed incorrectly to start with?
    Would a professional drawing normally even include dimensions on the isometric view?
    Thanks,
    Hi Neil,
    Good to know, thanks!
  • PeteYodisPeteYodis Moderator, Onshape Employees Posts: 569 image
    @Pahl When drawings typically show dimensions on an isometric view, those dimensions are called "True" dimensions.  This distinguishes the dimension from a "projected' value as is typical in other drawing views.  We do not yet offer true dimensions in Onshape drawings.  It's not often requested for the reasons Neil cites.  There are circumstances where the "true" dimension might be preferred, but usually you can create a view of your geometry where the projected value is what you want to show.
    Hi PeteYodis,
    True dimensions, good to know. This is just a hobby for me, but I really want to be as professional as I can about it.
    I started out wanting to learn CAD for 3d printing. Started with SketchUp. After 30 days of working with SketchUp I purchased my first 3d printer.
    Shortly after that I ended up coming across Fusion 360. From there I worked with Fusion 360 for about six months before I come across OnShape.
    So that's been my limited experiance with CAD so far, but I have to say that I'm very impress with OnShape. I don't know if CAD can be a hobby itself as I started out thinking I was going to be getting into the 3d printable hobby craze and CAD would just be a tool I use for it, but I enjoy the CAD side of things probably 10x more then the printing part of it as of now. Maybe I need a better printer haha.
    Thanks again for OnShape and keeping it free for guys like me.
  • Giovanni_PengueGiovanni_Pengue Member Posts: 1 ✭✭
    Same disappointment here...I was looking forward to put a true dimension on ISO view to make a drawing much more clear
  • JanaLumiJanaLumi Member Posts: 4
    I also would find it very useful to have the "true" measurements in the isometric view. It helps to quickly convey ideas when putting together requirements during product development stages. I have little to no use for projected values.
  • S1monS1mon Member Posts: 3,985 PRO
  • yonatan_lehmanyonatan_lehman Member Posts: 6
    I too would liked to add true dimensions to iso drawings.
    Personally I think that until this is possible there is no point in allowing drawing of dimensions that are wrong and meaningless. It's just confusing and error prone especially to newbies like me
