I have put these white dots everywhere and I have no clue how to remove them
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,990 image
    Not seen that before, probably a graphics glitch. Try holding shift and pressing the browser refresh button.
  • _anton_anton Member, Onshape Employees Posts: 532 image
    Do they persist if you hide the sketches? I expect they're projected line centers from other entities. You can also go into the sketches and delete the points if you don't need them.
  • S1monS1mon Member Posts: 4,082 PRO
    Those just look like sketch points that got created inadvertently. If you hide all sketches, do they go away? It looks like sketch 4 is shown.
  • andrew_mitchell145andrew_mitchell145 Member Posts: 4
    I think you’re right. I think it’s a glitch. Because I tried to open a new project and the dots where still there.
