How can I cut or subtract a surface from another surface?
Hello all,
maybe someone can help me here:
The gray area is a circular area . I want the area that is between the blue area and the gray area as a new surface. So how can I subtract the blue area from the gray area?
Thanks for the help and best regards
MichaelPascoe Member Posts: 2,213 PRO
Hi @tanja_matzerath, There are a few different ways to achieve this. Here is one way:
Thicken the surface that is the tool so that it is a solid part, then Boolean subtract it from the target surface.
Currently, the Thicken remove does not allow subtraction directly with surfaces which is why I split it into two separate steps.
https://cad.onshape.com/documents/28f352e014fdf64c7ef7a324/w/649360b4662905ff29942cf3/e/39bf686f4c36f2
CADSharp - We make custom features and integrated Onshape apps! Learn How to FeatureScript Here 🔴0
this worked: surface substract | Part Studio 1 (onshape.com)
@stvnvl_8501 Extrude is good if the surface is flat and will allow the extrude. Thicken will handle it even if the surface is not flat. I'm sure there are even more robust ways to do this.
Thank you for your comment. It helped me a lot and I was able to fix the problem.
