I recieved an SLDPRT file that is a bridge I am trying to turn that in crown.
dillon_hogg
Member Posts: 7 ✭
I've partially edited the SLDPRT file to remove the base so it could sit on your head like a crown. But I am having issues using the revolve or wrap tools to make the entire bridge wrap around in a circle. This is the name of the part "Roberto_clemente_bridge.SLDPRT"
nick_papageorge_dayjob
Member, csevp Posts: 1,034 PRO
Do you mean you would like the bridge to be a 360 degree circle, so it fits on top of your head like a King's crown? If so, you'll probably need to model that from scratch.0
I am sorry about that I'm still very new to onshape.
https://cad.onshape.com/documents/25aef54714bfaba35375e99c/w/973a9c4618a529cbe68a3c45/e/939e4165c8d38cf6e7133dd8
Something like this? Take a look in both part studios. I used an export dxf of a surface to get a wrap sketch.
https://cad.onshape.com/documents/c3b424034951b26406d55cb1/w/515fd0296ceb003d2a5417ad/e/b20c1d41d9e8e1c2da292d82
