How to loft this shape into circle?
Hello, I've been trying to loft a mushroom-like profile into a circle so that it creates a funnel.
However, I keep getting an error and it won't loft
How do get this to work?
Thank you for any help.
-M
-M
By making the points symmetric, I can easily drag them around with "final" selected in order to dial in the shape.
I've added six points and mirrored them but I'm still having the same result. What do you mean by "'final' selected"?
Did you just draw points on the circle?
You'll have to divide the circle into segments or use match connections in the loft.
Try the match connections. You will need to actually select the matching points.
There is a video in the help file that gives a good demonstration for how to.
https://cad.onshape.com/help/Content/loft.htm?cshid=loft
I used the split tool and the result was the same.
Is the split command sme as the split tool?
Thanks Glen Iit worked!
cheers.
On the left are points on a circle and on the right the circle is split like S1mon is taking about in a sketch. Both work. So which ever is your preference.
Split in solid mode splits a 'part' not a sketch entity. Different tools with different results. See attached example.
https://cad.onshape.com/documents/010058c1b66b2494ff19266d/w/e817dc7d53797384b33c6169/e/2065a878b4c2205a92e53cbd
Thanks. I used the split on the sketch..Thanks again for your help
-M
