Is it possible to turn a replicated part in an assembly into a new part?
tgunrtgunr Member Posts: 45 ✭✭
I have two parts, a base part representing a chuck and a jaw part. In the assembly I orient the jaw to the chuck and then did a circular replication to get the other two jaw parts oriented correctly. Now, I need to make the two new jaws into separate parts to modify the thread positioning. Is that possible or do I have to duplicate the jaw part and add them to the assembly?
https://cad.onshape.com/documents/f2a08ff5f25f577f9f067f93/w/5706a45d36601809f31c5c23/e/dd20d61ead28e2cd21a699c5
  • wout_theelen541wout_theelen541 Member, csevp Posts: 198 PRO
    You need to duplicate them replicate will only take the first instance as a seed.
  • MichaelPascoeMichaelPascoe Member Posts: 2,591 PRO
    edited July 2023
    This could be accomplished using configurations and a single jaw part studio and either some in context edits of the assembly or a derived base as a reference in your jaw studio.
  • tgunrtgunr Member Posts: 45 ✭✭
    Kind of figured that but thought I would ask. Would be handy to create a new instance as a part.
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,019 PRO
    edited July 2023
    Did you model the chuck body, jaws, and the scroll in the same studio? If so, circular pattern the jaws there, and use the threads of the scroll to control the threads in each jaw. You could even Boolean subtract the scroll threads from the jaws. Although those threads would then need massaging to be correct from a machining standpoint.
  • eric_pestyeric_pesty Member Posts: 2,387 PRO
    You really shouldn't be creating copies the entire jaw part studio!
    Just do a circular pattern of the jaw in your original jaw part before the tread features and derive in the "thread" part (rather than the other way around)
