I recieved an SLDPRT file that is a bridge I am trying to turn that in crown.
dillon_hoggdillon_hogg Member Posts: 7
I've partially edited the SLDPRT file to remove the base so it could sit on your head like a crown. But I am having issues using the revolve or wrap tools to make the entire bridge wrap around in a circle. This is the name of the part "Roberto_clemente_bridge.SLDPRT"
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 1,049 PRO
    Do you mean you would like the bridge to be a 360 degree circle, so it fits on top of your head like a King's crown? If so, you'll probably need to model that from scratch.
