Convert document units of measure from mm to cm
I started with drawings in a document.
My problem is that I started with millimeters, but now I need everything in centimeters.
Can I have everything converted to centimeters?
It is best not to simply transform and scale up.
Example: A measurement is now 30 mm and I want to convert it to 30 cm.
  • Matt_ShieldsMatt_Shields Member, Onshape Employees Posts: 844 PRO
    Change your document units to cm.  Then use transform.
