Difficult geometry
stephan_sonnenscheinstephan_sonnenschein Member Posts: 6 PRO
Is there a way to model this in Onshape? What would be the approach?
  • MichaelPascoeMichaelPascoe Member Posts: 2,253 PRO
    edited July 2023
    Hey @stephan_sonnenschein,
    There are multiple ways to do something like this. Here is one approach you could take:
    • Create the base piece with a sketch profile and a Revolve.
    • Create the main body using Loft. This will require a start and end profile, any in between profiles, and some guide profiles. Alternatively, you could use the custom feature Variable Section Body by @Konstantin_Sh to make this part more precise.
    • Use the Shell feature to shell the lofted shape.
    • Boolean add the lofted shape to the base collar.
    • The square holes will be tricky, you will most likely need a custom feature for this. I recommend Attractor pattern by @Evan_Reese.
    https://cad.onshape.com/documents/1ddacd6cd265a0a76e218577/w/cc9eabd418726825da2ced4d/e/dcb32fd7967e...
  • stephan_sonnenscheinstephan_sonnenschein Member Posts: 6 PRO
    It get's even more complicated. The wrapped ribs actually need to be hollow because that's where the water flows.  So I guess the Attractor patter won't help here. I've seen a video of somebody doing it in Solidworks and part of the solution was using a twisted loft I think that could be a way but so far I haven't had success doing this in onshape.
  • nick_papageorge_dayjobnick_papageorge_dayjob Member, csevp Posts: 945 PRO
    I thought this looked familiar. Was that video on youtube where the youtube guy had hired 3 remote cad modelers to attempt to make this?
    Yes, exactly. Actually he wanted to test what offerings he would get from people offering their service and most didn't even want to take this on and two did with different quality of the result.
    edited July 2023
    Hm, in that case, you will probably need some sort of Contour spiral or 3D Spiral that follows the path. @Konstantin_Sh wrote this one as well. It should be possible to spiral along the path then split the surface. From there you can thicken the surface inward and then hollow the final part.
    It might also be possible with a normal Loft and a single profile. You would have to match the connections so that they twist. Not sure this way will work.
    Another way may be to have several profiles and loft them. Each one slightly more twisted.
    Thanks Michael! I'll investigate a little more, will try the spiral approach and will also try a little harder if a loft twisted via defining the connection points would work. I'll probably report back tomorrow...
    @Evan_Reese, B) Knew you could do it! I was having trouble implementing it. Looks like the feature pattern did the trick.
    It's funny in the youtube video I think the guy payed something like $100 for the model. IDK, that just dilutes everything. Can you imagine how much experience one needs to model this?
     Evan, -Amazing!! That’s it. Had a quick look at it late at night. I’ll study the steps in every detail tomorrow. I’m glad it can be done in onshape, I was a bit in doubt for a while. Thanks again, Michael Pascoe too
  • EvanReeseEvanReese Member, Mentor Posts: 2,333 ✭✭✭✭✭
    I mean, to be honest, my first thought was "Onshape isn't the right tool. I'd use Rhino for this", which might actually still be true, but Onshape can do it. Rhino would allow me to model it straight and bend it later, which is much easier, but not as updateable, and would move it out of my main development tool, which both have major downsides.
    Independent Onshape Consultant | Industrial Designer
  • GWS50GWS50 Member Posts: 446 PRO
    wow that's impressive....I wouldn't know where to be begin! Lovely job.
