Difficult geometry
stephan_sonnenschein
Member Posts: 6 PRO
in General
Is there a way to model this in Onshape? What would be the approach?
EvanReese
Member, Mentor Posts: 2,825 PRO
Aw, Michael you beat me to it with Contour Spiral, but I did model it out. This is a very challenging model, but once you get the workflow it is fairly flexible. You could shell it after the pattern to get the hollow spiral parts. Mine is just a workflow proof of concept. It's not meant to be perfect.
https://cad.onshape.com/documents/9158f5120f43a70cc7da6d25/w/97409d83725eab473231455f/e/27eb13f7d047644019cdce18
7
Hey @stephan_sonnenschein,
There are multiple ways to do something like this. Here is one approach you could take:
https://cad.onshape.com/documents/1ddacd6cd265a0a76e218577/w/cc9eabd418726825da2ced4d/e/dcb32fd7967e...
Hm, in that case, you will probably need some sort of Contour spiral or 3D Spiral that follows the path. @Konstantin_Sh wrote this one as well. It should be possible to spiral along the path then split the surface. From there you can thicken the surface inward and then hollow the final part.
It might also be possible with a normal Loft and a single profile. You would have to match the connections so that they twist. Not sure this way will work.
Another way may be to have several profiles and loft them. Each one slightly more twisted.
@Evan_Reese,
