change colors
Hi there. is there any way to change colors of parts of the model from inside the assemblies? what is the right way to change colors in the assembly?
thank you!
thank you!
Pattabi Member Posts: 54 ✭✭
@bari Currently, It's not possible to change the colour of a Part in the Assembly Tab.
But it can be achieved by Workaround create the in-context part in the assembly and then copy the assembly to in-context part studio then you have the possibility to change the colour to parts.
See the below video for more details.
Not sure what your workflow is or the exact reason for the question but...
One idea would be to set up a configuration of the part with appearance configured. Then you can swap configurations at the assembly level.
How to change part appearance at the assembly level:
