Are sketch features not supposed to snap to assembly contexts in context?
ArnarArnar Member Posts: 4
When I make a part studio in context of an assembly, I'm frustrated by the fact that lines and sketch features don't snap to the features in the assembly context. Is this intended? Is there some setting I need to change? I don't quite see the point of part studios in context if this is not changeable. Thanks in advance
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,938 image
    There is no "snapping" but you can make as many constraint references as you like.
