Onshape is not connected... problem.
john_halliwelljohn_halliwell Member Posts: 3 EDU
"Onshape is not connected. Your document is saved. Refresh the browser to continue working on this document."
  • Windows 10 Home 64-bit Version: 19045.3208 -- Intel(R) Core(TM) i7-6700T CPU @ 2.80GHz -- 8 GB -- Memory slot 1  4GB Samsung 1600MHz -- Memory slot 2  4GB Samsung 1600MHz -- System board 2B3E 1.05 -- System BIOS A0.06
  • Video -- Graphic device 1 Intel(R) HD Graphics 530 -- Current resolution 2560 x 1440 -- Refresh rate 60 Hz -- Version 25.20.100.6446 (11/19/2018) -- Graphic device 2 AMD Radeon (TM) R7 M370 Version 27.20.1034.6 (8/21/2020)
  • Audio -- Device 1 Conexant HD Audio Status Enabled -- Driver CHDRT64.sys Version 8.65.131.52 -- Device 2 Intel(R) Display Audio Status Enabled -- Driver IntcDAud.sys Version 10.26.0.3
  • PattabiPattabi Member Posts: 54 ✭✭
    It's best to escalate the issue to Onshape support from the Document itself.
  • john_halliwelljohn_halliwell Member Posts: 3 EDU
    Thank you for your advice.
    FYI: Onshape is now working perfectly on the same machine. Possibly due to driver updates?
  • MDesignMDesign Member Posts: 1,041 ✭✭✭✭
    I see that message often on my under-powered little laptop. but its mostly due to 1 of 2 things. 1) I got distracted and left the computer for too long, Or 2) my internet connection got laggy for no reason other than its run by the phone company. …sigh… Most of the time its #1. haha.
  • rick_randallrick_randall Member Posts: 402 ✭✭✭
    edited October 2024
    Bad internet service (intermittent connectivity issues) is the only time I've seen that message
