Has my question about the wheel looking so strange been published?
ProApeProApe Member Posts: 206 ✭✭
Hi,
Since, unusually, the question you ask only appears when there is an answer to it (if I understood correctly), but as there was no answer to my question about what could be the cause of the wheel I drew looking so strange, I don't know if it was received at all.
Kind regards
ProApe
  • S1monS1mon Member Posts: 3,768 PRO
    What looks "strange"? Can you be more specific?
  • ProApeProApe Member Posts: 206 ✭✭
    That jumps right out at you!
    Unfortunately, the document has suddenly disappeared from my list of documents!
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,926 image
    Coincident parts - hide some of them
    Ok, thanks!
