Smoothing a 3d curve
Hello,
I am struggling to attempt to figure out how to smooth
this given curve I have created. It was made using an arc and a
projected curve attached to a straight line, meaning that I cannot
simply fillet it or something of the sort. How could I properly smooth
this line to create an organic sweep path?
EvanReese Member, Mentor Posts: 2,478 ✭✭✭✭✭
I'm glad you got something that works how you want, but I feel sure there's a better way. Does this do what you need?
https://cad.onshape.com/documents/9a5d0197acaa34d0db828f01/w/88eead3c3b83d131c9e9cba0/e/eec57f22edecd8d913909c0c
Or,
a spline with only two points, each tangent to the line/arc at each end (if you need the whole arc) then dimension the tangency of the spline for total control. Bridging curves do something similar but are more suited to turns in 3d. This appears to be a 2D sketch,
You may then want to make a composite curve from the 3 items.
M
and a 3d extrusion
https://forum.onshape.com/discussion/20638/improvements-to-onshape-april-12th-2023/p1
https://cad.onshape.com/documents/5e7b129d3112105f68f9ed86/w/3a45d529de437cf5951ac230/e/f04f96bd5c4a804df637a392
Vote here
You have two options, either keep the starting point in the end of half circle on the left and with keeping it tangent, you can use eg. Bezier curve to achieve tangency on both ends. It will create orange curve, which has tangency marked in yellow and has two Radiuses.
