linear pattern of parts in assembly to independent parts to allow relative translation or rotation?
ash_watson
Member Posts: 4 ✭
So I'm trying to do a quick motion study using an assembly with 4 instances of the same part connected to two other parts via revolute connections.
The parts were generated as a linear array instances from a parent instance.
I get this message when trying to animate.
I'm guessing this is because they were generated with set spacing as a linear array... is there a way to remove this constraint?
See what I'm trying to do in the "Motion study" assembly studio here:
https://cad.onshape.com/documents/97de899c50f8203962c47007/w/9d5cd8b78c52c971ca8c719d/e/05c752a8a718278d0b22a481?renderMode=0&uiState=64c1543aa1bca15af209b31b
Any tips and tricks much appreciated
