println units
hervé_piponhervé_pipon Member Posts: 60 ✭✭
Hello
Here is a small piece of code:
    var sketchPlane = evOwnerSketchPlane(context, { "entity" : definition.selectedEdge });
    var n = 100;
    var samples = evEdgeTangentLines(context, { "edge" : definition.selectedEdge, "parameters" : range(0, 1, n) });
    var origin = worldToPlane(sketchPlane, samples[0].origin);
    println(origin * centimeter );
It prints :
    (0 meter^2, 0 meter^2)
I want to display centimeter : what is wrong ?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,838
    Units in println are always meters, plus you are multiplying origin (which has length units) by another length to get an area.
  • hervé_piponhervé_pipon Member Posts: 60 ✭✭
    NeilCooke said:
    Units in println are always meters.
    @NeilCooke Thanks I didn't know.
  • Jacob_CorderJacob_Corder Member Posts: 137 PRO
    change your println to this
    println(origin / centimeter );
  • EvanReeseEvanReese Member, Mentor Posts: 2,319 ✭✭✭✭✭
    If you wanna get fancy with it
    printLn("origin = " ~ roundToPrecision(origin/centimeter, 3)~ " cm";
    This will print "origin = 3.25 cm" or whatever. You round to not display 3.250000000001 or some floating point value.
    Usually this isn't needed, but if there are a ton of things printing it can be nice to label them with strong concatenation.
    Independent Onshape Consultant | Industrial Designer
