println units
Hello
Here is a small piece of code:
var sketchPlane = evOwnerSketchPlane(context, { "entity" : definition.selectedEdge });
var n = 100;
var samples = evEdgeTangentLines(context, { "edge" : definition.selectedEdge, "parameters" : range(0, 1, n) });
var origin = worldToPlane(sketchPlane, samples[0].origin);
println(origin * centimeter );
It prints :
(0 meter^2, 0 meter^2)
I want to display centimeter : what is wrong ?
println(origin / centimeter );
This will print "origin = 3.25 cm" or whatever. You round to not display 3.250000000001 or some floating point value.
Usually this isn't needed, but if there are a ton of things printing it can be nice to label them with strong concatenation.
Independent Onshape Consultant | Industrial Designer
