FeatureScript TableData not effective.
hervé_pipon
Member Posts: 60 ✭✭
I write a FeatureScript which has to import a csv file :
export const CSV_Path = defineFeature(function (context is Context, id is Id, definition is map) precondition {
annotation {
"Name": "file"
definition.myPathCurve is TableData;My problem is that half the time the file is not read
The script starts correctly,
If I click again definition.myPathCurve.csvData == undefined
And on the next click it works .... and so on...
How can I make it works all the time ?
It is likely that you are not waiting enough time for it to load the data. To test. just hit the green check box and wait a minute. if you go back in and reload it again and check box makes it work then its a bug. I suspect your issue is due to not waiting for the loading wheel to be finished
I have both Part Studio View , and FeatureScript Notice View open at the same time.
When I click , I can read on FeatureScript Notice a message generated by my code that indicates that definition.myPathCurve.csvData == undefined
if (definition.myPathCurve.csvData == undefined) { println("Undefined Path Curve !"); return; }There is no need to wait more...
Sorry for this wrong question
