I got a problem :# Iworked a long time on an projekt....
f_p479
Member Posts: 9 EDU
I want to extrude my little projekt but every time i do it says cant be done because the extrudet parts would overlap.....
I dont know what to do and it would be realy sad if i cant complete it.. here is the projekt would be nice to know if there is anything i can do: https://cad.onshape.com/documents/0e98f0fd17c8b57aa932d27e/w/e21b82ae3bb13e42be09f641/e/8250e27afa55fe2a6102efed
If it's not possible no problem...
Thanks for the answer 👍
https://forum.onshape.com/discussion/9107/forum-post-checklist-read-this-first#latest
This will allow us to make a copy of your document so we can come up with a potential solution.
Do you have a vector version of the original artwork or is this done with some sort of auto-trace of an image? In either case, going back to the original and looking at all the import/conversion options might yield a better starting point.
Thanks for the
Thanks for the
Thanks for the
Either way, Onshape is a 3D program. You would have to draw the motor or the Nintendo using the native Onshape features. The drawing you have is best used as a visual guide printed on a piece of paper. This is true of any CAD program.
Thanks for the nick_papageorge073 said: The motor👍 the console was just inspiration😁
If CAD practice is your gaol, do all the tutorials on part modeling and assembly built into onshape. It should take you about 2 weeks of daily use to complete them all. After that, you will have all the knowledge needed to model the engine, and make an assembly of its components.
Wenn es nicht möglich ist, kein Problem ...
Danke für den Nick_papageorge073 sagte: Der Motor👍die Konsole war nur Inspiration
