Can't open Step files
fabio_maccarifabio_maccari Member Posts: 3
Hello,
I'm trying to modify some STL files, so I converted them into STEP files.
I can open and work the files on a different CAD on both PC and Ipad, but I can't open them with Onshape:
Some files can be opened but they only shows lines. No surfaces or shapes;
Some file shows their preview on ipad but I can't open them.
Some files shows this, if I try to open them:
  • fabio_maccarifabio_maccari Member Posts: 3
    Can anyone help with this?
  • S1monS1mon Member Posts: 3,418 PRO
    What messages show up (under bell icon)? The tab with the .STP file won’t show anything. Does a part studio eventually appear (it takes time after the initial file upload)?
    You should probably report this to support.
    As @S1mon says, check if a new Part Studio has been created (click the home icon, bottom left to go up a level). The notifications dialog will tel you if the translation was successful. BTW if coming from Shapr3d, Parasolid would be the best format.
