change default states
joshua_samsjoshua_sams Member Posts: 28 PRO
hi,
how do i change this list?
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,970 image
    You can't - it's a built-in system property. You could create your own, but then you'd have two.
  • joshua_samsjoshua_sams Member Posts: 28 PRO
    are there any plans to change this? is there any other way to change the watermark?
    No and no, unfortunately. You can turn it off (option in Release Management) and create your own though (see 4th video here for ideas).
    thanks for the idea.
    unfortunately it needs to be automatic. the current watermark isn't super visible and we keep ending up with in progress drawings at manufactures
    obviously company culture needs to changes but i was hoping i could add something like "not for manufacture" in the watermark to try help the situation
    nevermind
